Features:
Six inputs including phono - MM & MC, CD, tuner, video, tape 1 and tape 2.
Independent listen & record operation
Bass & treble controls with tone defeat switch
Other controls: balance, volume, speaker on/off, and power on/off
Outputs: headphone jack, 2 tape outputs, & 2 preamp-main outputs
Speaker connections by metal binding posts
Specifications:
Frequency Response: Phono: 20-20 kHz /- 0.5dB; Line stage: 3 Hz-65 kHz ± 3.0 dB
Power Output: 50 watts per channel into 8Ohm
THD: 0.05%
Signal / Noise Ratio: MM Phono: 78dB; MC Phone: 75dB; Line stage: 80dB; Power amp: 90dB
Channel Separation: -60 dB @ 1kHz
Phono Overload: MM: 175 mV @ 1 kHz max; MC: 10 mV @ 1 kHz max.
Inputs: Phono MM: 2.0 mV/47k/85pF; Phono MC: 110µV/100ohms/3.3nF; CD, video, tuner, tape 1 & 2: 100mV/20 kOhm; Power amp: 707 mV/50kOhm
Polarity: Non-inverting
Record output: 100mV; 1 kOhm
Preamp output: 707mV
Headphone match: 8-2 kOhm.
Dimensions: 17.5" wide, 2.9" tall, and 13.2" deep
Weight: 19 lbs
Ovo su slike "iznutrica" mojeg Audiolaba. Napominjem da sam mijenjao unutarnje ožićenje, driverice su mijenjane i podešene mirne struje. Nema tih novaca koji bi kupili ovog starkelju od mene. Nakon 25, čak i više godina još uvijek je kao nov.
