SPECIFICATIONS
Optical reading system (compact system)
Type 3 beam semiconductor laser pickup system
Rotational speed 200 ~ 500rpm, linear speed 1.2 ~ 1.4m / s
CIRC2 error correction scheme dual error correction method
Number of Channels 2 channel stereo
Sampling frequency of 44.1kHz
Bit depth 16bit linear
96dB dynamic range
SN ratio 97dB
2Hz ~ 20kHz ± 0.5dB frequency response
Total harmonic distortion 0.001% (1kHz)
Channel Separation 96dB (1kHz)
Wow and flutter below the detection limit
Terminal output 2V (0dB)
Headphone 32mWMAX/32?
Search by 10KEY T No. / INDEX SEARCH
UP / DOWN KEY of song selection jump
Manual search of FF · BWD KEY (queuing)
16 random songs available memory
Display T No. / INDEX No. / Memory state display the cumulative time over the remaining
Other features reserve features, functions invert, the sub-code output terminal
20W power consumption
Maximum Dimensions 440W × 95H × 313Dmm
Weight 9.1kg
